Urgent - overheated on side of road
I've got steam and coolant spitting out of what looked like a fitting on the bottom of the intake manifold on the drivers side...there are two coolest hoses attached to the fitting. I've got a video but I don't think I can upload from my phone. I'm thinking I'm gonna let it cool all of the way down, fill up the coolant reservoir to the brim and try to make the 3 mile drive home later. Any other ideas?
I don't think I'd try it at all, honestly. Because "overheating" by the time you notice (temp gauge in the red) is often times too late. If you have a way to monitor coolant temps and can keep it below, say, 230, you'll be fine.
I bypassed my throttle body heater by only using the hoses the vehicle provided. There was a plastic hose going to, a rubber hose going out (or vice versa). I joined the two using nothing but a hose clamp by slipping rubber hose over the plastic one, and it's been solid for 10k since. I'm sure you can do the same, unless your in/out hoses are busted.
I had to bend both at an awkward angle, which may or may not impede flow, but I consider this just a coolant loop. I should plug both ends and be done, but am too lazy. In short, my throttle body doesn't receive coolant (a major leak point before I did this), but I don't care!
1. Change the coolant to green antifreeze. The stock orange Dexcool can cause serious issues.
2. Be sure to read how to bleed the coolant system in the RAVE. It is necessary and important.
3. Buy an ultragauge or if you have an Android smartphone, buy a scanner. Download the app Torque for your phone and you're done.
4. I didn't replace the gasket on my leaking throttle body heater, I just cleaned it very well and used a tiny bead of RTV to seal it. Hasn't leaked for almost two years now.
hey all, quick update from me on the coolant issue. i've ordered the throttle body heater kit and will be replacing in the next couple of days. i continue to go through quite a bit of water as i have to drive the truck around town for work (a mile here, a mile there kind of driving). i assume that i am losing water because it is boiling off as i drive. my temp gauge moves towards the high end but i havent gone into the red yet.
ive researched flushing the system and it looks like the best way to do it is by disconnecting the top hose of the thermostat and letting the coolant runout from there. (do i have to use the block drain plugs?) ill put the garden hose up to those hoses and flush in both directions until it's clear. ive been running tap water in it for the last week since i overheated-i realize thats not optimal but i didnt have a choice at the time.
the RAVE manual indicates dexcool but i see that's not necessary from this forum-thank you for that)
any other tips i am missing?
