URGENT: Spark Plug Job, A No Go. URGENT!
Okay, I started the plug job using the "without removing IM method" by DeepBlueWater. Started by taking off the 8 and 2 wire from coil pack. Took off the #2 spark plug. I am having trouble putting the new spark plug in into #2.
I ordered the Bosch +4 part number 4418. It seems that everyone is using the same part number?? Its not fitting, it seems like I am making a new thread pattern.
I am very afraid if that happens, the block will be damaged.
Quick, help!!!!!!!!!
Grab another one of the spark plugs that you have and try to thread that one.
If it still wont go then try one of your old ones again.
Also make sure that the treads in the head are clean, no dirt or anything.
Take your Liquid Wrench and spray anything that may be in/on the threads/hole and clean them really well.
Do this to all the cylinders.
One at a time of course.
Yes, I tried putting the old one back on but it also has trouble. I don't have any liquid wrench, would carb cleaner would for the moment?
Its been 6 hours. I need to take a break, my knees are about to burst!!!
