US Trailer 7 pin trailer wiring
Old May 17, 2020 | 10:13 AM
ab1200max's Avatar
Default US Trailer 7 pin trailer wiring
Hey folks has anyone wired a 7 pin US trailer wiring kit WITH brakes?? Does anyone know where i can get a disco 2 compatible brake controller.
Many thanks
Old May 17, 2020 | 04:24 PM
frostythor's Avatar
Not sure what you mean the Disco 2 has a wiring block fitted on my car behind the rear right side light cluster, I just needed to by a Land rover trailer light plug and attache it to my tow ball the pass the trailer cable up inside the right side of the bumper and it plugged straight in no joints to make
not sure what you mean by brake controller, ?
Old May 17, 2020 | 05:59 PM
mollusc's Avatar
See the information on connector C1481 in the RAVE manual for the Discovery 2. This connector is located behind the right tail light assembly. It should be possible to source a standard 7-pin harness to plug into that, or wire one yourself. A brake controller could be mounted in the same area as part of the harness.
Old May 18, 2020 | 03:46 AM
frostythor's Avatar
You can buy a TD5 wireing kit it comes with the connecting block attached, can you explain what you mean by "A brake controller "
Old May 18, 2020 | 08:26 AM
mollusc's Avatar
Why not do a Google search for "trailer brake controller"? It's a pretty common thing.
Old May 18, 2020 | 11:22 AM
frostythor's Avatar
Yes did that, .......now I know why I drive a 20 year old car, very little electronics,!
Old May 18, 2020 | 12:00 PM
mollusc's Avatar
A brake controller really doesn't have anything to do with the vehicle. It's associated with the hauled weight of the trailer.
Old May 18, 2020 | 12:35 PM
ahab's Avatar
My '04 came with this installed, the gray plug was connected to the tail in the cavity behind the passenger tail light cluster. I assumed that the orange red and blue wires would be used for trailer brakes, and that you'd need to furnish your own trailer brake controller. There doesn't seem to be a place to connect them to in square box, but I know very little about his sort of thing. I'd like to know more if someone else has any info.
Old Jul 12, 2020 | 11:24 AM
kccode1's Avatar
Actually trailer brake controllers have been around longer than 20 years. They used to hook into the brake hydraulic line off the master cylinder to activate the electric trailer brakes. My grandfather had one in his 1978 Buick Electra because he pulled a 34 foot camper. Now they use accelerometers to send the power.
Anyway I an wonder the same thing. Our 2014 Ranger Rover already has the 7 pin installed but is the harness to hook up to the controller under the dash somewhere?
Old Jul 12, 2020 | 02:12 PM
Extinct's Avatar
U-Haul and Etrailer both have kits.
