USB Scantool.net
Old Mar 14, 2009 | 10:03 AM
Mackin's Avatar
4th Gear
Default USB Scantool.net
Trying to figure some things out with my 97 Discovery and am having a very hard time. Replaced VSS, MAF,Plugs, wires,fuel pump, filter and still having issues. Codes throwing is P0300, P1316, P1193. I bought this Scantool that hooks to laptop and am able to pull quite a bit of info. I noticed that the O2 Sensor 1 Bank 2 drops from .0920 V @20% st fuel trim down to .075 V @ 20% st fuel trim. See I am pretty tired of putting money in this just swapping out thing not fixing my sputters and inefficient running. Car idles and runs great just sputters when accelerating. So would this O2 actually be my problem? and which one is it? Also once the vehicle hits OD it has a shake. Can I test an O2?
txs
Old Mar 14, 2009 | 12:22 PM
Mackin's Avatar
4th Gear
Default P0300, p1193, p1316
what a pain in the rear...trying to figure all this crap out on the GEMs.
Old Mar 14, 2009 | 08:18 PM
The GEMS is the simplest engine management system out there, it is only two steps removed from a carburetor.
No a O2 sensor will not cause hesitation during acceleration.
A bad O2 will cause bad MPG but thats it.
Run long enough with bad O2's and you will carbon up your valves and that will cause bad run problems.
A bad knock sensor, cam sensor or crank sensor may also cause these problems.
What grade and brand of gas are you using?
sierrafery
Feb 21, 2010 10:50 AM
shanekelly55
Oct 11, 2006 03:37 PM
sydneysport
Oct 1, 2006 09:18 PM
sydneysport
Sep 24, 2006 11:33 AM
Autogeek
Detailing
Apr 22, 2005 06:27 PM
