Use Gasket sealer on throttle body heater rubber gasket?
Old May 13, 2016 | 12:17 PM
bcolins's Avatar
Default Use Gasket sealer on throttle body heater rubber gasket?
Just watched the Atlantic British video on replacing the throttle body heater plate and gasket. When reassembling he uses "High Tack" gasket sealant.
Seems like sealant shouldn't be needed on a rubber gasket.
Suggestions?
Brian in Cedar Park.
Old May 13, 2016 | 02:53 PM
mollusc's Avatar
Pretty sure he explicitly says that he's using the tacky sealant to hold the gasket in place while he mounts it, and that you don't really need to use it.
Old May 13, 2016 | 03:40 PM
bcolins's Avatar
Thanks,... guess I missed that you don't really need it.
Old May 14, 2016 | 10:58 AM
NickAdams's Avatar
Mine was not leaking when I did my intake manifold gasket, but I went ahead and "refreshed" it since it came in the kit. Started leaking less than a year later, so the second time I covered the gasket with a very thin layer of Blue Hylomar. That was about three years ago; no leaks yet.
Old May 14, 2016 | 12:32 PM
bcolins's Avatar
Was thinking about it last night, and also thought of Hylomar, but was concerned about the thickish rubber gasket squeezing out somewhere,....so, decided to go with a thin layer of Ultra Black, lightly tighten until it began to squeeze out a bit, then let it cure for an hour before final tightening (per the instructions)
Brian
Old May 14, 2016 | 02:07 PM
Best4x4's Avatar
I properly bypassed all my D2 Throttle Body Heater Plates, and removed it completely from the throttle body zero leaks, zero worries!!! I've owned plenty of V8's made around the same time period from Jeep's to GM, and Ford products and not a single one of them had coolant going to the throttle body! You don't hear about them sticking in cold weather either.
I think it's overkill in my book and even a working and non leaking Throttle Body Heater Plate still has the chance of leaking or causing serious damage due to the weak and brittle OEM hard lines breaking.
Old May 14, 2016 | 09:34 PM
dr. mordo's Avatar
Ha! I only used RTV on mine. I didn't see any point in the gasket. It hasn't leaked now for 2, maybe 3 years.
Personally, I use some type of sealant on every gasket I install. I consider it cheap insurance.
jycsalas
Feb 16, 2015 10:33 AM
mln01
Feb 5, 2015 09:59 PM
KernowDiscovery
Dec 10, 2013 07:22 PM
tylor36
Oct 2, 2013 02:26 PM
Disco_Fever
Aug 15, 2009 02:43 PM
