Used Engine?
Old Feb 5, 2022 | 04:29 PM
gleepglorp's Avatar
Default Used Engine?
Two questions to those who are familiar with this:
1. Where do you guys look for an affordable used engine usually? Or has anyone had luck with a re-manufactured one?
2. Can a 1999-2002 D2 engine fit in an '03 Model? I've read that the 99-02 have had less reliability issues than 03's or 04 (knock on wood). Also, would I need an SAI engine too? I don't use the SAI feature.
Old Feb 5, 2022 | 04:56 PM
tnrangerover's Avatar
Roverguy.com. honest trustworthy and great prices for used.
yes a 99-02 will fit. you'll love power I believe. SAI only connects at the heads, so use your old heads and any year block. you can use a P38 Range Rover Bosch block as well
Old Feb 5, 2022 | 05:11 PM
Harvlr's Avatar
Yes you’ll lose some power. 99-02 is 4.0 and 03-04 is 4.6 litre. May or may not concern you.
Old Feb 5, 2022 | 06:36 PM
mollusc's Avatar
SAI isn't something you use. It's something that the engine uses.
If you get a short block, SAI won't be an issue since you can reuse your existing heads, as Harvlr says.
Old Mar 9, 2022 | 11:32 AM
gleepglorp's Avatar
Just a quick update. I'm past 133k and the engine is STILL going, that being said it's going to go soon. When it does I'll be taking the Rover to a nearby "guru" to replace the engine with a 99-02. Thanks for the help and advice everyone.
Kinggarlic25
Engine Swaps
Feb 17, 2020 03:24 PM
gatorm
Aug 11, 2017 04:04 AM
mule2ears
Nov 5, 2015 11:37 AM
RegT
Mar 18, 2013 05:20 AM
FightOnUSC79
Mar 10, 2011 09:44 AM
