Used Vehicle Inspection List?
I'm looking at a DII and, unfortunately, can't be there in person to check it out since it's out of state. Here's a list I put together for a mechanic to look at:
Anything else I may be missing that should definitely be added?
Thanks
Coolant Pressure Check/Expansion Tank
Compression Check
Oil Pressure Check
Water Pump and Viscous Fan
Power Steering Fluid and Hoses
Diff Fluid
Air Conditioning
Wheel Hubs and Bearings for play
Drive Shaft Play
Engine Codes
Suspension Bushings
Tie Rod Ends
Windows and Door locks
Cruise Control
Truck does have CDL and no sunroofs. It recently had Valve Cover Gaskets, Oil Pan Gasket, and Transfer Case Gasket replaced.Compression Check
Oil Pressure Check
Diff Fluid
Air Conditioning
Drive Shaft Play
Engine Codes
Suspension Bushings
Tie Rod Ends
Cruise Control
Thanks
began
11-23-2008 08:59 AM
