Used Vehicle Inspection List?
Old Jun 22, 2020 | 10:41 AM
specops1526's Avatar
Default Used Vehicle Inspection List?
I'm looking at a DII and, unfortunately, can't be there in person to check it out since it's out of state. Here's a list I put together for a mechanic to look at:
Coolant Pressure Check/Expansion Tank
Compression Check
Oil Pressure Check
Water Pump and Viscous Fan
Power Steering Fluid and Hoses
Diff Fluid
Air Conditioning
Wheel Hubs and Bearings for play
Drive Shaft Play
Engine Codes
Suspension Bushings
Tie Rod Ends
Windows and Door locks
Cruise Control
Truck does have CDL and no sunroofs. It recently had Valve Cover Gaskets, Oil Pan Gasket, and Transfer Case Gasket replaced.
Anything else I may be missing that should definitely be added?
Thanks
Steve Wasko
Jan 15, 2019 07:18 PM
greg4500
Nov 13, 2017 10:01 PM
amamdani
LR4
Oct 26, 2016 10:53 AM
DooDer
Oct 8, 2009 09:33 AM
began
Nov 23, 2008 08:59 AM
