Using Dye in a coolant system?
I have a small coolant leak that I have been working with, turns out the hose in the upper right corner of the radiator had started to go bad and leaking a bit so that is solved, it also looks like the throttle body gasket has leaked in the past (from dried splatters of coolant) so I have a new one of those on the way and will replace this weekend, but it does not appear that is where the coolant is coming from on the reg, but I am still getting a few drops when I park it from that right hand corner of the car. Questions:
Is it safe to use dye to find a leak?
Are there any trick to finding a leak that I am not aware of other than spending $50 for a compression test?
My current plan is to get under the hood, wipe everything down and stare at hoses until I find something that doesnt look right but I was wanted to see if anyone had any additional insight or know another common right side collant leak other than throttle body or that hose.
Engine front cover
That is just for color, you need a UV light for that dye also. I don't use dex so I just use the green dye. You can use the green dye in dex it will of course change the color to green so keep that in mind if someone top off your coolant and thinks its green.
aguison
Nov 18, 2012 05:15 PM
