Using RAVE to replace ignition wires
The last time I did this job I used the instructions posted in the BBB to replace the wires w/out removing the intake manifold. Although the post was EXCELLENT, I just got too damn frustrated with the process so this time I'd rather go about it the official way and just take my time and remove the IM. Trouble is, though, that I can't find it anywhere in the RAVE CD. Does anyone know where it is?
Sorry, I was looking at the page number on the Adobe Reader, the actual number is 32-2-15 (lower right of the page) for the non SAI and the SAI starts right after that. It's in the "manifolds and exhaust systems - V8" section
I've never looked for instructions in RAVE about the wires, but you're correct, I can't find it either. The closest is replacing the coil packs in section 18-2-80 (which is a handy page to print if you're ever uncertain about where the wires plug into the coils) Odd thing about the coil replacement instructions is that they apparently want you to leave the wires attached to the coils as you pull the pack out. So I guess (in a perverse way) these are the instructions for replacing the ignition wires)
daxter1987
06-03-2023 06:35 PM
