Vacuum Gauge for Disco 2
Hello
I'm considering installing a vacuum gauge on my 2003 D2 SE7. A vacuum gauge is also called a fuel economy gauge where it shows if you are driving your vehicle economically or using fuel.
Does anyone here know how to install this gauge? I was told that you simply attach it to the intake manifold but I don't know the exact place in my LR Discovery
Thanks
Al
'03 D2 SE7
Thanks
Al
'03 D2 SE7
Old style technology, but it will prompt you to "feather foot", or drive like you have an egg between foot and gas pedal. You can connect with a T to any vac line that runs to the intake manifold. Test with device plugged in under hood before making final mount inside.
Thanks for replying. But I was looking for specifics regarding where the actual vacuum lines are on the vehicle, or maybe someone can direct me to the right page on the Rave manual on finding where they are.
Al
Here is what I got on a 4.0 D1. There actually are a number of things the vac gauge can show an old school mechanic, back when you could diagnose vehicles without megabytes. When you put pedal to the metal (or electrons, in case of the electronic throttle Rovers) that gauge is headed toward zero in a hurry.
You saw these on cars in the 60's, and some Mercedes later on. On the GM ones it was to prompt you to keep your foot out of the back two barrels on the 4 barrel carb. Some Dad's would disable the linkage in a vain attempt to control teenage drivers. A Pontiac Bonneville with a factory stock 421 and two Carter aluminum four barrels was a sweet running vinyl lined gas hogus maximus. You stuck to the vinyl unless you were running 70 with the windows down.
on
Don't waste your money. If you want to improve your MPG look at your air pressure try 40 pounds all the way around, tune up with new 8 mm silicone wires like STI's or Magnacor's, do an induction cleaning and stay off the gas pedal.
What octane are you burning and what is your current MPG in town and on the road?
