VACUUM HOSE ROUTING? 1994 DISCO I
I have downloaded and looked extensively at the RAVE Cd, but I cannot find the info I am seeking. I have a 1994 Disco I, with 3.9 V8 Fuel Injected engine.
I cannot find any diagram showing correct vacuum hose routing. Not the big hoses, but the little hoses.
For instance, exactly where does the small vacuum hose to the fuel pressure regulator connect to? I know it is supposed to have manifold vacuum on it, but I can't figure out where to attach it?
There is a short length of small hose that comes out of the side of the air filter box, that is not connected to anything. Any clues?
Ths idle air control valve has what appear to be 2 small nipples that look to be for small hoses, in addition to the big hose and electrical connector. Are hoses supposed to be attached to these, and if so,, where do they go?
RE: VACUUM HOSE ROUTING? 1994 DISCO I
ORIGINAL: dodge_mich
I tried to snap a pic but the camera doesn't fit so well back there.
The small hose on the lid of the box goes to the rear top of the driver's side valve cover...as for the others, I'll take your list out and try and write it up...
THIS IS GREAT, exactly the kind of info I need. Now, if you can describe where the other vacuum hoses go in my original post, I am in business. Thanks.
marksmetals
12-01-2013 06:57 AM
