valley pan gasket ?????
Old Feb 16, 2010 | 06:15 PM
03discoman's Avatar
Default valley pan gasket ?????
hey guys... my 04 motor needs a new valley pan gasket, when i removed the original one... it had some extra stuff molded to the bottom of the gasket... the new one doesn't have it.... any worries that silicon cant fix?
Old Feb 16, 2010 | 06:22 PM
lipadj46's Avatar
Talking about these?
http://www.roverparts.com/Parts/ERR7283.cfm
There is also RTV required at the end notches.
Old Feb 16, 2010 | 06:37 PM
03discoman's Avatar
yes.. those stupid things.... great.... know i have to wait for those also
Old Feb 16, 2010 | 06:45 PM
antichrist's Avatar
If you're near an Autozone you can get a Felpro MS96002 valley pan gasket that includes the end seals, for less than just the seals from AB. It also includes a tube of RTV.
About $13 for the whole kit from Autozone.
Old Feb 16, 2010 | 07:24 PM
03discoman's Avatar
so this is a valley pan gasket set withthe end seals?
Old Feb 16, 2010 | 07:49 PM
antichrist's Avatar
It's the valley pan gasket, two end seals and a tube of RTV.
Old Feb 17, 2010 | 08:44 AM
grussell's Avatar
...and use the RTV! I did a HG job a few months ago and per RAVE I put RTV on the ends of the end seals and torqued the bolt to spec and now my rear valley seal is leaking. When I fix this leak I will RTV the whole end seal and not just the ends.
Old Feb 17, 2010 | 09:00 AM
lipadj46's Avatar
When I did the valley pan I RTV'd the entire valley ends and right up around each coolant passage.
Old Feb 17, 2010 | 05:55 PM
jycsalas's Avatar
me too
Old Feb 17, 2010 | 10:31 PM
grussell's Avatar
Yep live and learn. I am going to redo mine when it warms up a bit.
