valve clap/tap
valve clap/tap
Hey guys :
The weather has been cold up here in Candada forthe past 3 weeks. between -4 and -10 My disco started making clapping/tapping soundz on startup . i did an oil change and switched to 5w 30 the sound is still there on startup. but it goes away as soon as the engine warms up. is this a valve clp/tap and should I be concerned?
RE: valve clap/tap
Dont worry about it.
DII's are known for this, apparently the rocker arms are aluminum with steel liners in the cup that the lifter goes into and these liners wear/come loose and rattle.
The good news is it will get worse and do it all the time, the bad news is it will do this for the rest of its life.
If you switch to full syn you can prolong the onset of a full blown lifter noise when your truck is running.
RE: valve clap/tap
The tapping noise comes from your lifters, rockers , tappets, etc. After it warms up the noise goes away because the lifters are able to receive oil pressure to build up the gap. Thinner oil flows better in engines that have sludge issues. RoverTCV8 has a point with the ATF treatment, as ATF is a detergent and it helps clear up sludge.
RE: valve clap/tap
ORIGINAL: sloppyjoe
for the love of god put synthetic in there,,,
its sitting right on the shelf next to that archaic crap called conventional motor oil. your engine will thank you for it.
After all..
Its not a Rover if its not Leaking..
And I want to be part of the CLUB!!
RE: valve clap/tap
ORIGINAL: llPANCHOll
Im going to do this very soon
After all..
ORIGINAL: sloppyjoe
After all..
then there must be something wrong with my 04 then because i swapped to synthetic as soon as i bought it and it does not leak[:-]
