Valve Covers Leaking
Old May 19, 2009 | 10:44 AM
humroot's Avatar
Default Valve Covers Leaking
Hey Guys,
I have a leak from the back of my v/c's. And yes, I have tightened them to 10 ft/lbs and they still leak. I tightened them Saturday and cleaned the area and took a 100 mile trip on Sunday. when I checked last night they were still leaking. About 2 years ago I had a mechanic replace them and had to take the truck back once because they started leaking again within a year. I'm using Mobil 1 10W-40 high mileage syn.
I think I will be replacing them myself, so what else should I do while I have the intake off? I already have Magnacor wires. Would like to take care of everything that I can while the intake is off. Appreciate any suggestions!
Thanks,
Old May 19, 2009 | 11:01 AM
jycsalas's Avatar
I replaced mine after tightening them no longer helped. I used the AB gaskets and have no leaks after about 2 months. I hear (from discoweb.org) that using the original buick 215 vc gaskets are better.
i bought the gasket kit from AB. http://www.roverparts.com/Parts/9218B.cfm and replaced all those gaskets in the kit. Just make sure you NEED to do the valley pan cuz if it's in good shape, and you mess up installing the new one, you'll be unhappy pulling everything apart again...
But you can buy the recommend valve cover gasket, Felpro part number #VS12993R-1 from rockauto.com for $13 and hopefully have better luck than others.
I'm also running mobil 1 10w40
Old May 19, 2009 | 11:51 AM
humroot's Avatar
Excellent! Thank you! So how long did it take you?
Old May 19, 2009 | 12:21 PM
jycsalas's Avatar
I replaced the thermostat, belt, i painted the valve covers black, i cleaned everything i removed, replaced plugs and wires and did all the gaskets in that AB kit. PLUS replenished the coolant. I did all this while installing the CDL kit so it was down for about 2-3 weeks. I took my time since i had another car to use.
I would say if you just replace the valve cover gaskets and clean everything you remove, label bolts and nuts, then it could take about one full saturday maybe even half of sunday. just plan for two full days. after doing it once i would plan it taking me one full day on another disco but much faster on mine since i replaced all my clamps and my baby is squeaky clean. just take your time. don't plan for it to be done in one weekend, unless you plan on doing it THIS weekend since you have 3 days off, (hopefully)
Some other guys may say it took them A LOT less so it really depends on your mechanical ability and how fast you work.
Old Aug 13, 2009 | 04:17 AM
Greg Duncan's Avatar
Hello there guys. Just a reminder..
Replacing the Valve Covers is no easy task. But make sure you buy valve covers with the best quality since this is one sensitive engine part.
Old Aug 13, 2009 | 07:38 AM
lipadj46's Avatar
The Atlantic British rocker cover gaskets are working well for me so far. To remove the valve covers the upper intake manifold has to come off so you will need that gasket also. Unless your valley pan is leaking I would not remove the lower intake manifold. Removing the rocker covers are good anyways because you can see if your engine is sludged or not, if so you can decide if you need to switch to a better oil.
PowerTrip
Dec 2, 2011 10:19 PM
msm15
Jul 19, 2011 04:18 PM
d.m.disco
Mar 14, 2010 11:08 PM
masism
Jun 7, 2009 08:53 PM
raid13
May 12, 2007 06:05 PM
