vehicle waddle
Old Jan 27, 2009 | 04:40 PM
WayneR's Avatar
Default vehicle waddle
my 95 disco has pretty bad "vehicle waddle". While following the wife home, I noticed the vehicle not driving straight/square/true. When parked the truck has a lean to the passenger side. I thinks i have to inspect the suspension. Not ever working much on this truck other than regular maintenance....anything i should be looking for when she's on the hoist? shocks, coils, bushings? should there be any play anywhere?
cheers,
Wayne
Old Jan 27, 2009 | 07:21 PM
Default RE: vehicle waddle
Well I had a similar problem, check the bolts on your trailing arms, mine were loose, tightened up and problem fixed.
As for your lean, you need new springs.
As for not tracking true, you need a alignment.
Old Jan 27, 2009 | 07:27 PM
Spike, I thought of you when I read this.
Someone needs to get under that truck and measure and retorques every bolt the can reach.
Old Jan 27, 2009 | 07:33 PM
This is exactly why I post the things that I find/fix with my truck Mike.
So that if somebody does a search maybe it will come up and help them.
https://landroverforums.com/m_99231/tm.htm
rover_lover
Mar 23, 2007 01:35 AM
absolute_offroad
Jan 8, 2007 06:08 PM
madelynne168
Sep 15, 2006 03:24 AM
MizLiz
Mar 26, 2005 10:47 PM
