Vents, louvre's and other heat transfer methods
Old 03-01-2019 | 05:37 PM
Tomzsix's Avatar
Default Vents, louvre's and other heat transfer methods
So we can all agree, then. that the head gaskets are the achilles heel. Has anyone had any success on removing heat buildup from the motor?? Can you re- route the hoses?? Vented scoop on the hood?? Side vents like the Range Rover??
Old 03-01-2019 | 06:23 PM
cfz2882's Avatar
when the cooling system on mine was in proper working order,it had no problem at all keeping temps normal in 105*heat water pump is a little small on these engines ,but the radiator and fan are very good.I know some Rover drivers have modified the coolant piping from the stock arrangement to an in-line thermostat setup like "old skool"American vehicles use.My disco is an '03 that no longer comes equipped with an engine oil cooler like '02-earlier had-I might add-back an oil cooler when I do major engine repair this spring...
Old 03-01-2019 | 06:31 PM
jastutte's Avatar
i have two '04's. one with an oil cooler and one without. both have stock cooling systems with the exception of 180 degree thermostats. the '04 without the oil cooler runs a little cooler. it does have stock tires and suspension. the other '04 has a two inch + lift and 31 inch AT's. the both run 186-188 on the highway and 194-199 at idle.
my experience, in the U.S. Midwest, has been that the stock cooling system with a 180 thermostat is sufficient. for reference, here in Missouri we get summer temps in the upper 90's. still no cooling issues with my current setup.
oh yeah. no Dexcool for me. old school green.
Old 03-02-2019 | 09:37 AM
stillruns's Avatar
Saudi grill?
Old 03-02-2019 | 05:46 PM
shanechevelle's Avatar
Hood scoop.
I bet an old mopar style scoop mounted to the hood with a hole cut would vent heat and actually wouldnt look too bad.
The scoop on a subaru might look ok...
you could even attach the intake and maf to the underside with some creativity.
Old 03-02-2019 | 06:52 PM
cfz2882's Avatar
Noticing how small the water pump impeller is on the stock pump,i did wonder if an inline auxillary electric water pump like one of those Australian Davies Craig ones could be plumbed in to increase circulation at idle-such as stuck in gridlock at 100* with the AC blowing Have the aux. pump come on at ~210*, Certain late model cars have a variable speed electric pump instead of a belt driven one
Old 03-03-2019 | 04:31 AM
The head gaskets fail because of overheating, lack of maintenance, and a design flaw. Unless you're changing the motor, you cant beat the design flaw.
Old 03-06-2019 | 12:25 AM
No Doubt's Avatar
Inline 180 degree thermostat, Water Wetter, Saudi grill, passenger fender vent, AirTex waterpump, underbelly pan removed, proper bleeding, Hayden fan clutch, OEM shroud, and oversized radiator should go a long way.
You could also go to a larger oil filter which increases your oil capacity a little and you could add an oil filter heat sink onto it, as well.
*the Disco 2 hood itself is held onto its hinges by 4 bolts. There's probably a way to use longer bolts+spacers to slightly raise the rear of the hood near the windshield enough to provide some venting?
Old 03-06-2019 | 12:48 AM
User's Avatar
Shane.. I beat the design flaw.
My 02’ 4.0...180 thermostat, oversized oil filter, and BMW blue meant for plastic and aluminium cooling systems=180k miles without a single head gasket failure. Until I replaced it as preventative maintenance. It was not failing/failed. I think that truck still has its original radiator and water pump too. I don’t recall ever replacing them.
And I still run close to 188-195 in daily driving traffic and all.
I first used BMW blue as I had a BMW engine Range Rover back then. Had a lot of the stuff and decided to flush it with it.
Best decision ever. I use only BMW coolant on trucks I keep, at $24 a concentrate gallon it’s not pricey either.
Old 03-06-2019 | 05:27 AM
Curious, did you buy the truck new?
At what mileage did you replace the stat, coolant?
Quick Reply: Vents, louvre's and other heat transfer methods
