Vibrations over 70mph
been getting vibrations issues over 70mph(and I can feel it very slighty at 60ish), What should I check? Front DS been rebuilt, rear rotorflex was replaced(old one was in really bad shape), still there, balance and rotated tires, still there. also I have clunking noises when I go from like drive to reverse, and when crusing and slighting taping the gas I can hear it clunk.
any advice? im going to try to remove the drive shafts and see if it goes away.
or the ball joints are completely shot and your wheel is about to snap off the next time you make a hard left. I experienced a faulty ball joint that manifested itself in a variety of symptoms, 1 of them a shaking sensation at freeway speed, espc' when contacting something like 1 of those large cracks/pothole/lane dividers/etc
working
happy to report that I haven't needed to work on my truck since Sunday. My buddy lent me his OEM LR fan clutch so no fan/cooling problems since installing that; it was like 5 or 6 brand new Import Direct HD units part #2991 from O'reilly Auto Parts that have a manufacturing defect. I was driving myself crazy looking at my belt drive & everything associated with it. After replacing the water-pump, PS pump, belt-tensioner pulley, AC comp' bearing, idler pulley bearing, having the alternator bench tested....it turned out to be a whole run of bad viscous clutch units. SOAB!
You have to ensure the driveshaft is regularly greased at least twice a year until you see grease emerging from the UJ's otherwise they knack out very quickly.
