Voltage regulator replacement
For what it's worth, here is info from my ever growing parts cheat sheet for a Disco 2.
*DISCLAIMER* .... This alternator parts info may be obsolete and/or not definite. Please research and verify all the part numbers first along with descriptions and dimensions before ordering/buying...
Thor V8 120A Alternator parts:
***‘99 - ‘02 P38 Range Rover Bosch 150A alternator (#ERR5834 / #AL0809X) is a direct Disco 2 alternator replacement for a Thor V8***
- Bosch #AL0809N / #AL0807N (X=Remanufactured) alternator
- OEM BOSCH: #0123510073
- Component OEM Ref Price Rotor #1124035514
- Slip Ring #1124303007, #SLR39121 $2.88
- Copper Bushes that go on shaft: I have no idea the part #, but these were worn on mine
- Stator #1125045590
- Rectifier #1127319714, #RTF39930
- D/E Bracket #1125825542
- D/E Bearing #1120905510, #BRG6661, #B17-99LLU $8.16
- S/R/E Bracket #1125885551
- S/R/E Bearing #1120905525, #BRG62032RS, #6203 $2.24 (The smaller 6203 bearing in 2RS format (2-sided Rubber Seals) is same bearing in 70mm serpentine belt pulley and belt tensioner pulley. NTN & SKF are two good brands.)
- Regulator brushes #1197311549, #VRG46472 $45.60
- Brush #1127014028, #ABR5089 $1.44
- Voltage Regulator J&N #230-24103 - ZC-Voltage Regulator $39.95
Check out Maniac electric motors for rebuild kits and other parts. They have been very helpful.
https://www.maniacelectricmotors.com/discovery.html
Club Cheetah
06-09-2015 04:57 PM
