wanna do a lil work on my d2 and have some ?
Old Dec 8, 2012 | 02:26 AM
DiscoPhipps78's Avatar
Default wanna do a lil work on my d2 and have some ?
Ok so real soon id like to change my t-Stat and O2 sensors. Im not dumb by no means im just never really done any work on my own trucks except for oil and fluids really so what im getting to is what do i need to do such jobs and if yall could tell me where these are thanks ahead of time. I wanna teach myself mlabout my d2 so i can appreciate more than i already do.
Old Dec 8, 2012 | 03:21 AM
hilltoppersx's Avatar
first go download the RAVE manual. It's the workshop manual for your truck available for free here http://www.landroverresource.com/doc...hop_Manual.pdf
it's great that you have a good attitude about working on your truck.
is your check engine light on? or is there some other reason you want to change the o2 sensors? have you rebuilt or replaced your front drive shaft? you should familiarize yourself with common problems and once they are tackled then move on to other items.
When you do replace the thermostat I highly recommend a 180 degree thermostat it will allow your engine to run around 200 at it's peak rather then 210 with the normal thermostat. I would also switch from the orange (dexcool) coolant to a universal coolant like Peak.
Old Dec 8, 2012 | 03:22 AM
aarongregor's Avatar
PM me your number, I can walk you through this.
Old Dec 8, 2012 | 05:25 AM
The Driveshaft is already done before i bought it. My SES light is on ran the code it is my o2 sensors. And thats why i wanted to change my T-Stat b/c i want to put the 180 in.
Old Dec 8, 2012 | 07:29 AM
Here is a plumbing plan from the RAVE. It is a very good resource.
File Type: pdf
Old Dec 8, 2012 | 01:00 PM
sounds like an easy 2 hours of work ahead of you. just make sure you put the thermostat in the same way you took the old one out. Lots of people put it in backwards and can't figure out why the truck gets hot.
as for the O2's make sure there is no oil or anything dripping down that killed the ones you have currently installed. screw the new ones in connect em clear the code and ur good to go.
Old Dec 8, 2012 | 01:36 PM
lr2001silver's Avatar
Banned
Exactly what he said, make sure your connections are clean and then apply dielectric grease to the connectors before plugging them in it will also help to keep water out out of your connections. if you have that much fun!
roach
Sep 22, 2010 04:39 PM
sloppyjoe
Aug 16, 2009 01:18 PM
jy3
Jun 4, 2009 02:50 AM
DeShawn
May 5, 2008 07:02 AM
