want to add line to catch the water from Condenser
Old May 29, 2017 | 10:02 AM
BS50MGSXR's Avatar
Default want to add line to catch the water from Condenser
so i found were its dripping water for the A/C condenser and i would like to add some hose to it so its not dripping onto the front drive shaft anymore. what have you done ?
just looking for ideas is all before i start messing with it.
Old May 29, 2017 | 11:38 AM
Luckyjayb's Avatar
mine had enough to route it to where the u welds are to route it that way. If your hose isn't long enough, get a coupler and do it that way
Old May 31, 2017 | 06:07 AM
BS50MGSXR's Avatar
all i see is a nipple with cross cuts in it. why do they do that? why not just have a drain line ? do they want the water to collect till its full enough to slowly drip from that cross cut nipple?
Old May 31, 2017 | 08:18 AM
Best4x4's Avatar
I yank those nipples out all the time as they're known to clog up.
Old May 31, 2017 | 08:53 PM
BS50MGSXR's Avatar
so pull the nipple off and whats behind that? anything to attach a hose to? any guesses on a hose size or size of coupler to use ?
Old May 31, 2017 | 10:47 PM
Bom2oo2's Avatar
Once you pull nipple off, you will see a small funnel like rubber piece stays behind that makes the seal to body, the hole in rubber funnel is aprox 1/2 inch, you want a tube at least 5/8 to 11/16 inch outside diameter, so when you squeeze it into rubber funnel it doesn't fall off easily, I used some hard plastic tube that fitted just right, (don't push it in too far or some water will always stay in funnel,) I brought the 2 plastic hose from both sides to just slightly under Trans cooler line, & used 3/4 inch heater hose and slided it over plastic hose to make like a heat shield and keep it from possible melting, then ziptie then to Trans cooler line in a few places & cut the extra tubing so it doesn't hang too low, it has worked for me just fine & no more water on driveshaft or XYZ switch,
Old Jun 1, 2017 | 04:30 AM
OffroadFrance's Avatar
My A/C drain above the xyz switch was, I believe, 8mm ID, so I attached a 6-8" length of flexible rubber fuel tube to the existing tube after removing the split nipple and fixed the new tube tied back with a zip tie or two and then replaced the split nipple to the new tube. The problem was condense constantly dripping onto the xyz switch and not so much the driveshaft.
TRIARII
Off Topic
Jan 8, 2013 10:55 PM
Jaace
Jun 24, 2011 10:24 AM
Brownsurccapt
Mar 11, 2011 01:57 PM
groundandpound
Dec 14, 2010 05:09 PM
Phototone
Apr 16, 2008 01:14 AM
