Wanting to keep ride height but soften the ride
I have OME HD springs with OME nitro charger shocks. The ride off road is jarring and not enjoyable. Looking to keep the ride hight with heavy steel ARB bumper and arb sidesteps. What component is mostly responsible for the stiff ride? Springs? Shocks? Or a little of both?
any company make a progressive spring that give a smoother ride but will keep the height with a load?
not looking for a 70’s Cadillac ride but pot holes on a forest road feel like the axles are mounted to the frame by 2X4’s
The OME HD's will ride hard, a couple of questions
- Do you currently have the bumper and steps mounted
- Is your Disco loaded or empty
- Do you air down and if so to what
- How fast are you going
I had that experience with my non weighted down truck on new MD OME springs and Nitrocharger shocks. Super hard ride off road tires in mid 30’s PSI.
Finally I decided to try different shocks and went with the Terrafirma standard length. For me that made a huge difference. I’m not saying it was like air bags but it was a magic carpet ride compared to the OME shocks. A huge improvement.
I was surprised as the TF’s are much cheaper but are apparently more suited to the situation at hand.
Just my two cents.
Just my two cents.
Richard Gallant (01-07-2021)
Just my two cents.
Just my two cents.
You have HD springs meant to handle extra weight. Only way to really keep a decent ride & height would be to install some MD springs and then a 1inch spacer under the coil perches. That will get you a MD ride quality with the same amount of lift. I personally run MD springs on all but 1 of my D2's then I have 1inch aluminum spacers under the spring perches. HD is NEVER going to ride worth a darn unless you have the extra weight on your LR which is what the HD springs were rated for.
The following 3 users liked this post by Best4x4:
@Micmac It is really a combination which is the problem but sort of in order (as I understand it):
Spring support the weight on the axels to keep the body stable, too light a spring and you roll all over the place too hard a spring and the body roll is restricted but it become more and more like having no springs so you end up with no flex which as you can imagine makes the ride brutal
Tire pressure is important as too low makes vehicle stability at hi-way speed bad and accelerates tire wear as well as generating excessive heat. Too hard and you it becomes like running sold tires. The correct tire pressure helps absorb some of the road way imperfections
- Shocks
- Springs
- Tire pressure
- Load
- Shocks
- Springs
- Tire pressure
- Load
Thank you! All good info
Richard Gallant (01-08-2021)
Yeah, even with the TF suspension, I was a bit surprised how rough the ride is off road. I don't really understand why it needs to be so firm when it seems like off road you want a little bit of flex and give. I was also looking for softer suspension but couldn't really find too much. I wonder how the desert runner type trucks that go fast off road have it setup?
