Wanting to keep ride height but soften the ride
Many people confuse the HD designation to mean robust and beefy, but in actuality it is referring to load carrying capacity. Thus a lot of guys will just get HD because Heavy Duty equates to tough in their mind. While that may be true the reality is still HD is meant for heavy loads, any lesser load will be a jarringly rough ride.
Yep like I said before MD/HD coil springs will have a different load/spring rate vs OEM factory springs. MD is meant for vehicles with F/R bumpers, and a winch, without any of those the vehicle will ride higher than 2inch and the ride will be awful. Same for a HD rated spring. It's meant for F/R bumpers, a winch, a roof rack, and all the extra weight due to cargo, a roof top tent, or whatever your payload is, without any of that you could see 3inch lift, and a ride from hell.
That's why I do MD springs for my bumpers, winch, and recovery gear. I don't HD, but I did want the 3inch of lift so I added 1inch aluminum spacers. Best of both worlds I get the height and the ride I want.
Richard Gallant (01-09-2021)
I can attest to OME HD springs with ARB bumper and winch still has a bone ratting ride. I may switch up shocks first up from if no improvement get MD springs and 1” spacers up front. The ride for the rear doesn’t seem that bad.
FWIW, unless you are talking about the remote reservoir type... Bilsteins are not worth the extra $100 per corner.
I ran two sets of Bilsteins before I knew better... They ride about the same as OME Nitrochargers and in my experience wear out sooner. I think there must be a reason they are not marketed specifically for Rovers.
I have found when it comes to shocks, the most expensive is not always the best.
The standard length TerraFirma shocks, which oddly, are cheaper than both the OME and the Bilstein. And I've run all three brands in my 200k miles of ownership.
The first time I went off pavement I noticed the difference. The TF's actually dampened the ride rather than reinforcing the stiffness of the springs.
Been happy with my +3" adjustable TF shocks and the Fox shocks on my other rover are a bit harsh (no bumpers or armor and rarely loaded down but rides fantastic with some weight in it). I am picking up a pair of 10" 7100 remote resi from a buddy next week that I'll put in the white rover (probably the rear, I have a dream of 3 linking the front and running much larger front shocks this winter/spring).
Not knowing anything about shock sizes other than using the drop down menus for the make and model. What size shock should I look for with OME Hd springs and some Wt up front. Guessing it results in about a 2” lift
