Wanting to rebuild my front driveshaft...HELP, need part #'s
Old Jul 28, 2008 | 04:37 PM
2000 Disco 2 SD7's Avatar
Default RE: Wanting to rebuild my front driveshaft...HELP, need part #'s
ORIGINAL: Luv2Disco
The easiest and best solution is to simply take your truck to a driveline shop and have them remove, rebuild and replace your shaft for you. A competent shop will clean, paint, balance your shaft AND warranty the work. Good piece of mind if your tranny gets slappped, and isn't that why you want to do this in the first place? You should be able to get this done for less than $200 (parts and labor) depending on your location.
One last thing, many if not most mechanics will simply remove the shaft, take it to a driveline shop for rebuild, then re-install it themselves. Cut out the middle-man and go directly to the driveline shop! Really, this is no more complicated than getting your brakes done or similar work. Driveline shops just aren't as numerous so you may have to ask around. Good Luck!
Regarding driveline shops, anyone here from the Cincinnati area that can recommend one?
Old Jul 30, 2008 | 08:13 AM
Luv2Disco's Avatar
http://www.cincydriveline.com/
Below should tell you all you need to know...now, just go do it.
http://www.mvlrs.com/phpBB/viewtopic...0d185142217664
discomedic4
Apr 26, 2010 08:41 AM
domyo
Sep 25, 2008 12:17 PM
harrisoncope_1
Sep 5, 2008 12:47 PM
unstable
May 12, 2008 07:08 AM
unstable
Apr 29, 2008 07:15 PM
