Water in crank case.
Old Aug 26, 2009 | 10:52 PM
ChanchoVerde's Avatar
Default Water in crank case.
How bad is it when an engine leaks water into the crank case? Can someone please explain why this happens and also what it takes to fix it?
Thanks everyone.
Old Aug 27, 2009 | 06:42 AM
lipadj46's Avatar
You need new head gaskets. Coolant is leaking down through your cylinders into your crankcase. It's expensive to fix unless you DIY.
Old Aug 27, 2009 | 07:38 AM
I just saw an ad on a Disco for sale and wondered what the seller was talking about. Thanks for the explanation.
Old Aug 27, 2009 | 07:45 AM
lipadj46's Avatar
At least they are being honest. How much did they want?
Old Aug 27, 2009 | 08:03 AM
AK Rover's Avatar
On Rover engines it could also be a slipped liner allowing water in the crank case. Best case the engine needs head gaskets. Worse case the engine needs replaced.
outdoor7or24
Dec 22, 2014 09:31 PM
yloDiscoII
Feb 10, 2010 10:03 PM
DiscoveryHouston
Oct 1, 2009 09:32 AM
DiscoveryHouston
Defender
Sep 26, 2009 10:02 AM
falcontech
Feb 5, 2008 04:04 PM
