Water leak = dead radio
Old Feb 23, 2008 | 07:32 AM
nynole's Avatar
Default Water leak = dead radio
So we have had record rainfall in the Florida panhandle over the past couple of days, enough to realize that (after reviewing these forums) my sunroof drainage tubes are either blocked or disconnected. I was parked facing downhill overnite and the next morning I had water on top of my dash, a little pool of water in the pen/pencil holder on top of the dash and apparently some water made it into the radio itself. The headliner was also soaked from the left a pillar to the right a pillar along the top of the windshield. Well I turned the radio off and now it wont turn back on. I checked the fuses under the dash and they are still good. Here are my ?'s:
Where are the ends of the drain tubes located and can it be cleared with a can of compressed air?
If the tubes are disconnected, can they be reconnected without removing the headliner?
Is there a chance that my radio will dry out and start working again?
In the event that I need to replace the radio, would a aftermarket radio be compatable, or do I need to replace with LR OEM Radio?
-I would like to upgrade to SAT compatable unit but if I understand correctly, the radio is tied into the diagnostics and I am not sure that any radio is compatable.
Thanks for any input and if anyone has experienced a similar situation, I would love to hear about it.
Old Feb 23, 2008 | 10:47 AM
Default RE: Water leak = dead radio
Your radio should start working again after it dries out. Leave it off for 3-4 days and see what happens.
I have not heard of the radio being connected to the ECU but with a '03 who knows.
I went to Best Buy and had a Kenwood CD/SAT/HD Radio unit put in my DI. Radios are meant to be replaced when they go bad right?
You could also check http://www.roverlandparts.com/for a factory unit.
Old Feb 23, 2008 | 02:09 PM
souljad9's Avatar
I have a alpine 9883 in my 04. Sat ready, and Ipod controls. Also compatible with the steering wheel controls.
Stereo
http://www.crutchfield.com/App/Produ...p;i=500CDA9883
Steering wheel adapter
http://www.crutchfield.com/S-VtC3xpl...p;i=127SWIJACK
Then add either an xm or sirius tuner.
CaptainCulp
Jan 8, 2015 04:49 PM
oljohnboy
Apr 21, 2013 02:04 PM
agb2g2
Sep 30, 2012 11:36 AM
steveo3880
Aug 14, 2011 07:04 AM
Goldfield Rover
Aug 26, 2009 12:58 AM
