Water leak
Old Jul 2, 2017 | 06:27 PM
Luckyjayb's Avatar
Default Water leak
well I've determined the leak in the floorboard on the passenger side isn't from the a/c drain or from the roof. I wouldn't think it would be the windshield since it's new and sealed properly(from what I can see at least) so I'm at a loss. Any ideas?
Old Jul 2, 2017 | 07:24 PM
DKPhoto's Avatar
Ive noticed the same thing, I was thinking it was condensation from the AC line or vents. Its been really humid here in Florida... as usual and when it happened to me I had the ac on and the window down for a minute or two. Hasn't happened again for me to pin point the source.
Old Jul 2, 2017 | 08:07 PM
Luckyjayb's Avatar
I think the reason is the fact I'm missing #5 and #6 on the picture above and that might be causing the leak. I've cleaned the ac drains. The headliner is down since it's been getting redone and I double checked my sunroof and the drains and they are still good. I'm gonna get the parts from abran and hopefully it will fix it
Old Jul 2, 2017 | 08:46 PM
LR03NJ's Avatar
Hopefully its the 5 and 6. Mine has crack all over and does not leak. I'm not sure what is under the cowl but removing the suff around there takes time. How much water? Condensation perhaps like DKphoto mentioned?
Old Jul 2, 2017 | 08:50 PM
Luckyjayb's Avatar
It's more than condensation BC it will saturated on the passenger side and where I park leans to the passenger side
Old Jul 3, 2017 | 12:09 PM
DKPhoto's Avatar
Im going to check and see if I'm also missing these parts, this might help the both of us confirm this is what we need.
Old Jul 3, 2017 | 12:25 PM
DKPhoto's Avatar
Yep mine are cracked as well. Might do the same and check under the Cowl and see whats underneath. As far as the amount of water it was a decent drip but only left a small puddle on the rubber floor mat. It hasn't happened since and we've had rain so I haven't thought much of it until I saw this thread.
Old Jul 3, 2017 | 12:46 PM
LR03NJ's Avatar
HAHAHAHA! If you hang around the forums you'll see all thats missing and problems with your rover.
Old Jul 3, 2017 | 01:09 PM
Luckyjayb's Avatar
Well I'm in central Alabama and it has a brand new cowl and brand new a frame pillars. All replaced when the heated windscreen was professionally installed about 3 months ago.
Old Jul 3, 2017 | 02:20 PM
DKPhoto's Avatar
My Girlfriend is going to find a way to block me from the forums here soon, every time I scroll through them I find myself out in the car checking things and taking it apart. She thinks it stresses me out but as we all know we secretly enjoy it.
