Water leak over fuze box disco 2
Old May 12, 2012 | 08:51 AM
Squaddie's Avatar
7th Gear
Angry Water leak over fuze box disco 2
Hiya, after help please! Up until last night my motor was fine, after it raining all night, I discovered that there was no power to the car whatsoever, and only the srs airbag light on the dash. The Drivers side footwell was wet so opened the fuze box cover to find traces of water in and around the fuzes! I removed all fuzes and dried the area using a hair dryer but still nothing. Can any1 suggest anything please?
Old May 12, 2012 | 08:57 AM
jafir's Avatar
Disconnect the battery before you try anything.
Has your windscreen been replaced?
Old May 12, 2012 | 08:59 AM
Squaddie's Avatar
7th Gear
Ok will do, and the windscreen hasn't been replaced.
Old May 12, 2012 | 09:02 AM
jafir's Avatar
Just realized you're in the UK. I've not been in a right hand drive Disco. Is your A/C evaporator and heater core on the right side like it is in our LHD discos? If so your may have a plugged evap drain tube or leaking heater core.
Old May 12, 2012 | 09:08 AM
Squaddie's Avatar
7th Gear
I think so, I will go and have a look.
Old May 12, 2012 | 09:14 AM
You will need to dry out all your electrical system before reinstalling the fuses or you will have major problems.
Old May 12, 2012 | 09:26 AM
Squaddie's Avatar
7th Gear
Cheers mile will get on it now
Old May 12, 2012 | 10:29 AM
Squaddie's Avatar
7th Gear
Hiya mike, dried the electrics out, reinstalled fuzes, but nothing!
Old May 12, 2012 | 10:32 AM
Squaddie's Avatar
7th Gear
Jade, the A/c condenser is on Lhs and not leaking!
Old May 12, 2012 | 11:36 AM
Squaddie's Avatar
7th Gear
Cool
Finally got it sorted!!!!!! Thanks very much for your input guys.
