Water leak where headliner meets top of windshield
I came out this morning and jumped in the Disco,...and it was raining inside along the edge of where the headliner meets the top of the windshield. I haven't used the sunroof in years, and its electronically disconnected. So, thinking I probably have a sunroof drain that has given up somewhere. Wondering if I have to drop the headliner completely or if I can get a look at the drains by dropping just the front section over each front door (ish). Thinking I saw a tutorial on this years ago when I had another Disco with a leak at the rear.
Brian in San Antonio
Sixpack577 (11-14-2019)
Or you have a windshield leak. Or the crack in the corner metal at the top of the A Pillare where the rain gutter makes the corner.
Had any recent windshield work?
Check the top external corner for gaps and fill with clear silicone if so. The rubber in that area degrades over time.
Brian
There is a known issue of the metal seam between the actual A pillar and the roof can crack. Look for that at the top and underside of the corner of the metal part of the rain gutter where it welds to the A Pillar. Otherwise the windshield rubber seal can deteriorate at the top corner, look for that too.
I don't think the actual plastic rain gutter has anything to do with a potential leak.
Don't waste your time. Take off the A-pillar covers and the headliner. Use a house or a pressure washer to test:
1. The corners where the windshield meets A pillars.
2. The roofrack mounts
3. The windshield seal.
4. The front gutter areas that house the plastic raindrips
If you are putting putty here and there hoping for the best, the next rainfall may disappoint you.
bcolins (11-14-2019)
Richard, I tried moving the outer rubber corner windshield trim per the Tech bulletin,...but it felt like I would probably break the now hardened rubber if I attempted to bend it back on itself as they show in the bulletin.
@bcolins in that case I would run a bead of silicone along the outside edge if the two suggestions below do not work
You can also try hot water and a rag or a blow dryer on hot the idea is to warm the rubber up alot and see if it becomes more pliable
Very hot water - almost boiling
rag on top of the rubber corner
pour hot water on the rag
Let sit for 5 or so minutes remove and see if the rubber is more pliable with heat.
Not sure if this work for you as you are in Texas and it is generally warm there but it may help
