Water Leaks everywhere???
Old Mar 28, 2010 | 04:05 PM
marlymarl's Avatar
Default Water Leaks everywhere???
I rain all last night and this morning. I got in my 2000 Disco II and water was leaking everywhere. Is this from the sunroof?
Old Mar 28, 2010 | 04:47 PM
Danny Lee 97 Disco's Avatar
Default Sunroof Leak
Did you leave it open when you rained all night?
Old Mar 28, 2010 | 05:32 PM
lipadj46's Avatar
More than likely it is from your sunroofs, they have drains in them that get plugged or broken. There are many posts here and elsewhere on how to check and fix the leaks.
Old Mar 28, 2010 | 06:31 PM
jzhoward's Avatar
I had the same issue with my 03 DII. My headliner above the front passenger door (that whole front corner) was soaked! Mine had a faulty sunroof tray and simply unclogging/cleaning the sunroof drain tubes never helped the problem. You might try that first though since it's the least expensive route. My faulty sunroof tray led to a "body seam leak". Apparently this is the actual weld on the bare metal of where the roof meets the rest of the body. This required removal of the headliner and re-welding the problem area. I had this done at LR and without my warranty, it would have been about $1400 (including sunroof parts). So, hopefully it's not this. Def check sunroof drain tubes first.
Old Mar 28, 2010 | 09:48 PM
tweakrover's Avatar
This is the guy who, when you say your arm hurts, tells you; "My friend's arm was eaten off from the inside from flesh eating bacteria, but you probably just pulled a muscle." UUUHHHH
Old Mar 28, 2010 | 10:02 PM
Default Epitome of British Engineering
Precisely what is the meaning of the phrase "The Epitome of British Engineering" as you use it?
I thought the only well engineered British made things were their early WWII aircraft, they have never been known for production of highly engineered automobiles have they?
None come to mind.................. maybe Lotus
Old Mar 28, 2010 | 10:16 PM
tweakrover's Avatar
Well, yes it is sarcasm, but you gotta love em. Its like Rodney Dangerfield.
Old Mar 30, 2010 | 11:50 AM
Wolkesan's Avatar
you can try this: http://www.waterdoctors.com/
Old Mar 30, 2010 | 10:30 PM
TBIAgent69's Avatar
They had a special on the Lancia on Top Gear this week. Jeremy was having a pretty good run racing it around a track until it caught fire.
Old Apr 10, 2010 | 10:04 PM
The FPLRG loves watching Jeremy and his crew. They are wild!
