Water in my tail lights?
Old Nov 17, 2012 | 10:30 AM
BMF175's Avatar
Originally Posted by Bkreutz
Usually if you look real close you can see cracks in the surface of the plastic, it gets oxidized and hardened by the sun and starts to crack. Yes, water will affect your lights, if you don't want to spend the money to buy new ones, you could take the assembly out and drill a small drain hole in the bottom so the water could run out, then put the assembly back into the body.
This is what I did. It was a crack. Got some clear caulk in a small tube and sealed the crack I wiped away the exacess to leave only what would stay in the crack. Drilled the hole. Never had another problem.
Old Nov 4, 2024 | 03:37 AM
MAF Diver's Avatar
Originally Posted by Spike555
Drill three holes, two on the bottom, one on each side of the lens, one in the highest spot of the lens.
This allows the water to drain out and cross ventilation to prevent the lens from fogging over.
Use the smallest drill bit you can, they dont need to be big holes.
I did this to a Ford van, the corner lens filled with water, which is common on the Econoline vans.
Thats the pro tip! To drill 3 holes
From the inside right?
And it’s fine that the water then drains inside there somewhere?
Jeff Blake
May 30, 2018 12:42 PM
djkronik57
Apr 13, 2016 03:31 PM
Unshriven
Feb 27, 2012 05:31 PM
robdog
Oct 30, 2009 11:09 AM
fluffdaddy
Mar 29, 2008 06:24 PM
