Water in Oil 2001 Discovery Series II SE7 V8
HELP!!! We have a Discovery Series II V8 that had water in the oil and was overheating we pulled the heads and had
them pressure tested and surfaced (both were warped) reassembled and test drove about 15 miles with no problems. returned to shop and parked and let idle for 1 hour then it began to overheat and has water in the oil again. WE NEED HELP PLEASE!!!
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
You more than likely have a dropped cylinder liner. There are steel liners in the cylinder bore that can drop after the block overheats causing the gaskets to not seal properly. You need a new engine block. roverlandparts.com sells used complete engines, I can't find a site that sells just engine blocks right now.
YARRover
06-07-2014 08:49 AM
LandRo
11-06-2012 08:16 PM
Hoss645
08-18-2011 03:58 PM
SmyLeOrElse
12-29-2006 02:02 PM
00bm00
12-16-2006 06:48 PM
