Water in Oil 2001 Discovery Series II SE7 V8
Old Mar 21, 2008 | 02:25 PM
Craneman's Avatar
Default Water in Oil 2001 Discovery Series II SE7 V8
HELP!!! We have a Discovery Series II V8 that had water in the oil and was overheating we pulled the heads and had them pressure tested and surfaced (both were warped) reassembled and test drove about 15 miles with no problems. returned to shop and parked and let idle for 1 hour then it began to overheat and has water in the oil again. WE NEED HELP PLEASE!!!
Old Mar 21, 2008 | 03:48 PM
britishracinggreen's Avatar
Default RE: Water in Oil 2001 Discovery Series II SE7 V8
You more than likely have a dropped cylinder liner. There are steel liners in the cylinder bore that can drop after the block overheats causing the gaskets to not seal properly. You need a new engine block. roverlandparts.com sells used complete engines, I can't find a site that sells just engine blocks right now.
Old Mar 21, 2008 | 06:17 PM
Atlanticbritish.com sells short blocks, which is the engine without the heads.
Old Mar 22, 2008 | 01:37 AM
kraelo's Avatar
Craneman, just went through this SAME exact thing, found a used motor for $500 and am currently installing it
good luck !
LandRo
Nov 6, 2012 08:16 PM
Hoss645
Aug 18, 2011 03:58 PM
SmyLeOrElse
Dec 29, 2006 02:02 PM
00bm00
Dec 16, 2006 06:48 PM
