Water Pump leaking from small hole in front cover?
Old 05-05-2014, 08:57 PM
LADEROUTE's Avatar
Default Water Pump leaking from small hole in front cover?
We were away for a week and upon our return [before we took the Disco out for a drive] I checked the oil and coolant levels and topped them up. The wife took the truck for some errand running yesterday and this morning we noticed a puddle of coolant under the truck.....
I refilled the [now] empty reservoir and started the truck to see droplets coming from a small hole on the front of the water pump.
The seals around the pump are fine but when the engine is running there is a steady drip coming from this little hole.
It was fine before we left for vacation, what a welcome back!
Thank you in advance for any advice on what this may be.
Old 05-05-2014, 09:05 PM
ralphobell's Avatar
Old 05-05-2014, 09:13 PM
drowssap's Avatar
time to replace the water pump
Old 05-05-2014, 11:48 PM
LADEROUTE's Avatar
thank you for the information - very helpful link!
So I guess it's off the Atlantic British or Rovers North.
Is it worth springing the $359.00 for the Original Land Rover pump or will a replacement model suffice? Any experience with an aftermarket unit?
Atlantic British "Recommends" a mid price unit but it is hard to tell without seeing it if there are an differences.
Old 05-06-2014, 12:33 AM
montana968's Avatar
i get a lot of my parts from miami british.
Old 05-06-2014, 01:01 AM
Dave03S's Avatar
If you search on here I believe Disco Mike recommends a specific heavy duty water pump.
Old 05-06-2014, 06:42 AM
buick215's Avatar
You want to get the one with the solid brass impeller.
Old 05-06-2014, 07:09 AM
drowssap's Avatar
Is it worth springing the $359.00 for the Original Land Rover pump NO
PLENTY OF FINE AFTERMARKET WATER PUMP OUT THEIR
Old 05-06-2014, 07:25 AM
ralphobell's Avatar
Old 05-06-2014, 07:57 AM
dusty1's Avatar
I think that is an airtex branded unit
Quick Reply: Water Pump leaking from small hole in front cover?
