water pump leaking at weep hole
RE: water pump leaking at weep hole
Either the belt is to tight and it is causing the bearings to wear prematurely, not likely but possable, most likely is just bad pumps.
I imagine that the first one that you bought had a warrenty and the replacements were given to you under warrenty. If that is the case then you need a different brand of pump.
Dont get a replacement, get your money back. What brand of pump did you buy? The rest of us need to know so that we dont buy this brand.
02 model original pump locked up at 75K miles Ford dealer replaced pump don't know brand it lasted 30K We replaced it with Proline pump from Rovers North it lasted 9K Before installing last pump (warranty) we flushed system and installed new coolant Dexcol (orange) this pump has only lasted 3K. Rover North said they have not had any problems with these pumps and they are willing to give money back toward purchase of OEM Pump. Proline pump cost $90
