Water pump R&R
Old Jul 5, 2011 | 09:55 AM
drowssap's Avatar
yes, that is what you need.
I would and did buy the 36mm instead of the universal.
hell pay the shipping and you can use mine.
Old Jul 5, 2011 | 10:04 AM
sloan74's Avatar
drow, that belt I linked, is that the serp?
Hey, do i need both wrenches or just one of them to remove the fan? RAVE sorta confused me on that.
Old Jul 5, 2011 | 10:10 AM
DarylJ's Avatar
Originally Posted by drowssap
the stock water pump has a stamped impeller
If by stamped you mean "a big chunk of machined brass" then you're correct.
Old Jul 5, 2011 | 10:22 AM
drowssap's Avatar
you only need the one wrench, it really isnt on there ***** tight. a lot of people say they can get it with channel locks but I couldnt get anything that thin to fit in there.
you can try autozone or advances i think they lone them you just hace to check the size.
Old Jul 5, 2011 | 11:43 AM
sloan74's Avatar
I talked to my neighbor at lunch. He got his off his BMW with a large adjustable wrench. So we are gonna try to hit it with that versus me spending 45 bucks on that wrench. If the adjustable will not fit I will loan one from autozone, good call.
So which pump would you go with drow?
http://www.autopartswarehouse.com/de...MB1442001.html
or
http://www.roverparts.com/Parts/STC4378OE.cfm
Old Jul 5, 2011 | 12:49 PM
dcarr1971's Avatar
you only need the one wrench, it really isnt on there ***** tight. a lot of people say they can get it with channel locks but I couldnt get anything that thin to fit in there...
It's worth a try without the special wrenches, but if that doesn't work right away don't waste time or get frustrated...go get a 36mm fan clutch wrench.
...you can try autozone or advances i think they lone them you just hace to check the size.
A word of advice...don't waste your time with the 'loaner' fan clutch wrenches. I got sets from 3 different stores, and found that the 36mm wrench in every one of them was stretched to 37-39mm...just far enough to be useless. (Apparently, some Fords use 36mm too, so the loaner tools get lots of wear and tear.)
You should be able to walk in to your local auto parts store and pick up a 36mm fan clutch wrench for less than $25. With a fan clutch wrench that was actually 36mm, it took less than 5 minutes to get my fan clutch off. After wasting all the time trying different wrenches, then the junk 'loaner' tools not working either, the $25 was money well spent...
Old Jul 5, 2011 | 12:52 PM
sloan74's Avatar
Good advice carr. Thanks.
Old Jul 11, 2011 | 09:09 PM
amccullough's Avatar
+1 on the fan clutch wrench. Just about every auto part store carry Ford Fan Clutch wrenches which are 36mm. I use a long screwdriver to hold it in place, but i've also just thrown a rag between the belt and the pulley to hold it.
Old Jul 12, 2011 | 08:18 AM
sloan74's Avatar
Great Neck/2 pcs. fan clutch wrench set (27018) | Fan Clutch Wrench | AutoZone.com
Will that work?
Old Jul 12, 2011 | 08:42 AM
DarylJ's Avatar
Yes. All you really need is the 36mm.
