water pump replacement and overheating
Old Jul 9, 2017 | 03:08 PM
hankeester's Avatar
Default water pump replacement and overheating
I just replaced the water pump on my 04' Disco S and now it is overheating. I'm not new to this Disco (owned it 5 years and do all the work myself) so I am familiar with bleeding off the air in the cooling system and have done so before with success. I bled it twice after the WP install, cold engine, elevate overflow tank, purge out air through the valve on the upper top hose. Then start it with heater on full bore until it reaches op temperature.
So here's the question, as long as I'm driving it will stick around 188 and normally at stop it won't climb over 203 (put a 180 degree thermostat in it a couple years back.) But now at stop it will climb out of that range and if it reaches 208 I shut it down if I can't drive it, like at a stop light.
With that information on it cooling down while driving, could there be any other component that is failing that coincedently happened right after the water pump replacement?
I was going to try one more time bleeding it as I know it the past attempts I had bled twice to get all the air pushed out. Also before when bleeding it, if air was still in the system, it wouldn't blow hot air which is not the case. I should also mention that I drove it for two days after the water pump replacement and had 0 problems with overheating, that's probably what is really confusing me.
Old Jul 9, 2017 | 03:14 PM
Dave03S's Avatar
Try topping it off through the bleed hole. While cold of course. Last time it took me about 4 days to get every drop of air out.
Old Jul 9, 2017 | 03:45 PM
hankeester's Avatar
I did try adding some in there although with it pouring out during the bleed process I put the screw back it while the tank is still elevated to make sure I don't suck air back in.
Old Jul 9, 2017 | 04:44 PM
Dave03S's Avatar
just open the bleed screw in the morning, without elevating anything... If there is any air in there replace it with coolant.
Old Jul 9, 2017 | 05:11 PM
dtmbinb's Avatar
Sounds like a bad aux fan. Stick a long screwdriver in the grill, with the truck off of course, and try to spin it. If it doesn't spin, it's shot. Also, check the 40amp fuse. Good luck.
Old Jul 9, 2017 | 06:29 PM
No Doubt's Avatar
Yup!
He said that he replaced the waterpump, but didn't say that he simultaneously replaced the fan clutch.
Gotta do BOTH, not just 1!
Fan clutch is cheap on rockauto.com (no affiliation).
Old Jul 10, 2017 | 09:44 AM
hankeester's Avatar
Thanks for the help guys, did not know you had to do them at the same time. I will go with the screwdriver in the grill method and check the fuse.
Old Jul 10, 2017 | 11:34 AM
Motorhead1's Avatar
1) The electric fan doesn't come on until 212 degrees or you are running the AC.
2) Why did you replace the water pump? Because of the same issues you are having now? Heats up at idle?
3) Replace the fan clutch.
Old Jul 10, 2017 | 12:41 PM
hankeester's Avatar
Right on the fan, just looked that up. The original reason for WP replacement was it seized up and spewing coolant. No issues before it took a crap. The aux fan does come on at 212 though.
Old Jul 10, 2017 | 01:34 PM
Motorhead1's Avatar
Hopefully the only time you (everyone actually) EVER hears the electric fan on a Disco is only while you are using your AC on a hot day....
