watts link
Brandon318 (11-25-2022)
so it's clear, the 'curved' arms are for those trucks with a lift (2 or greater inches). The original arms are straight. Straight arm on driver side will interfere with the watts link support if the disco is jacked up (w/ springs, not body lift)
The clained 'OEM ones' are no way for sale for 200$. these are aftermarket. Anything with an original LR green sticker on it will be at minimum 300$ and up just for the watts link. The 3 center watts bushings are spherical and need to be for angles involved. That's why I would avoid the poly bush replacements for the main watts link. You can use poly on the arms to body mount...
as I said above, aftermarket center watts link w/new bushings will be fine. I have one and it works great. get one with bushings installed, they are a PITA to press out and in...
vette427sbc
09-09-2014 04:40 PM
