Weak brakes and weird abs codes
Old May 15, 2017 | 05:42 PM
escott16's Avatar
Default Weak brakes and weird abs codes
Alright so since I bought my rover it's always had this brake issue , ofcourse the three amigos are on which is a whole thing in itself , but the brake pedal when pushed feels really hard and I have weak brakes , no matter how hard you push the pedal you can't get the brakes to lock up or when the abs is working it won't engage that, the stopping distance is laughable , I checked all 4 calipers and lines and they seem fine , what else do you guys think it could be, also the codes I'm getting from my hawkeye are
fault 4012
Old May 15, 2017 | 07:12 PM
Twix's Avatar
Vac leak to your booster? Is it a V8 or diesel?
Old May 16, 2017 | 12:35 AM
escott16's Avatar
V8 I didn't notice any leaks when I checked
Old May 16, 2017 | 08:14 AM
jamestfl's Avatar
Hard pedal = brake booster?
Old May 16, 2017 | 10:57 AM
escott16's Avatar
I did the brake booster test I saw online awile ago where you press on the pedal and start the car and everything seemed to check out I will try it again when I'm on break at work but that abs code I got the people from Hawkeye and Atlantic British couldn't explain it
shezm
Feb 28, 2014 09:08 AM
shezm
Oct 20, 2013 10:16 AM
Bob Loblaw
May 1, 2013 08:56 PM
maxman
Jul 26, 2011 05:45 PM
