weird brake light behavior
Old Dec 28, 2017 | 07:23 PM
dougn's Avatar
Default weird brake light behavior
anyone seen this:
lights on and apply the brakes the left brake light does not light and the tail light goes off (that part may be normal). the light bulb is good of course
Old Dec 29, 2017 | 07:09 AM
naivedisco2's Avatar
I just fixed something similar yesterday. Running lights would not work, and brake lights didn’t work when headlights on or when in reverse. Turned out to be water in tail light causing corrosion, cleaned it all up and all lights work correctly. Not sure about just one side failing but it could be something corroded in the tail lamp assembly as all of those lights share a ground wire. For my issue both sides had the same problems, but only the right rear light assembly was corroded.
Old Feb 19, 2018 | 10:36 AM
dougn's Avatar
turned to be a flakey connection between the bulb and the fixture
Old Sep 14, 2018 | 09:35 AM
EarthRover's Avatar
3rd Gear
Originally Posted by dougn
anyone seen this:
Not to hijack this thread, but I have a vaguely similar condition, with left and right brake lights behaving differently, and it's not a bad bulb.
Will look for and attempt to remove any corrosion or similar issues, and see if that fixes it.
Old Sep 14, 2018 | 09:58 PM
No Doubt's Avatar
Inside the back hatch area of your Disco 2 on the passenger side is a plastic vented cover on the corner vertical pillar.
Pop it out and look inside.
I had a small electronics box in there that had a ground screw holding it on to the frame, except that it had come loose. I got really odd behavior from my taillights and brake lights until I found and screwed that ground screw back tightly onto that box.
Old Sep 15, 2018 | 11:00 AM
EarthRover's Avatar
3rd Gear
Studying the problem more closely, I see evidence of some wiring work having been done on this light before. I suspect the two live wires leading to the bulb (not the ground wire) may have been reversed. Will check this out.
Old Mar 10, 2023 | 04:40 PM
dparham's Avatar
here is what im seeing....
(WORKING running light) REAR RIGHT PLUG with headlights and ignition on:
BLACK TO PURPLE GREEN = 0 v
BLACK TO WHITE GREEN = 0.1 V
BLACK TO RED ORANGE = 13v
(NON WORKING running light) REAR LEFT PLUG
B TO PG = 0v
B to RG = 0.6v
B to Black Red = .6v
maybe a short to ground? or is there some other reason im not seeing?
gallaways
Mar 7, 2023 01:57 PM
RoverDiscoKiddo
Jan 29, 2012 09:45 PM
modernhomesteader
Jul 22, 2011 12:15 PM
willrok13
Jun 20, 2011 07:59 AM
Classic89
Nov 1, 2010 08:40 PM
