Weird head light situation
Old 03-10-2022 | 02:44 PM
Oshawa_D2's Avatar
Default Weird head light situation
Hey guys, I have a youtube link to my head light situation below but let me explain
the head lights physically work. When I disarm my alarm the headlights come on
prior to this situation happening, I would have inconsistent headlight function one light on and the other only on “day time” mode or none,
now my lights do not come on, the high beams are stuck on and will not come off.
there is a weird rapid clicking from behind the fuse box unless I turn head lights to on position.
I have unplugged the four relays in the photo while the clicking is going on and that does not stop the clicking
here is a video uploaded to youtube showing the issue .
https://youtube.com/shorts/FotgXloBZMY?feature=share
Old 03-10-2022 | 03:06 PM
Richard Gallant's Avatar
Well that is bizarre, that sounds like a tanked relay. There is a little fan in dash on the left side it might be related if it is your fuse box.
Old 03-10-2022 | 03:45 PM
Oshawa_D2's Avatar
you are right does sound like a relay but aside from those 4 in the photo, I dont see no other relays
Old 03-10-2022 | 03:47 PM
Oshawa_D2's Avatar
I forgot t mention. It happened once before and fixed itself the next day
Old 03-11-2022 | 08:13 AM
mollusc's Avatar
There are relays built into the passenger compartment fuse box, on the back side of the circuit board. They're not replaceable. Only fix is to replace the entire thing.
I believe that there are different versions of the fuse box for earlier and later trucks.
Old 03-11-2022 | 10:09 AM
Oshawa_D2's Avatar
I can try and order one from eBay there seems to be a few of them, however is there a way to determine that is the actual issue and not something else prior to ordering the fuse box
Old 03-11-2022 | 10:43 AM
mollusc's Avatar
You can pull the fuse box and open it up. My guess is that you might see evidence of something amiss inside, like dry solder joints or water/rust.
Unfortunately, it's not really possible to hook it up while it's open so you can observe things like the relays, because the wire bundles that connect to it are only just long enough to reach it when it's installed in its proper position.
Old 03-11-2022 | 05:18 PM
Oshawa_D2's Avatar
UPDATE
today the clicking noise that you hear on the youtube link is 1/2 the speed and the high beam is not stuck on anymore and the head lights and the fog lights both work.
what the heck is going on? 😂
Old 03-13-2022 | 04:04 PM
Oshawa_D2's Avatar
UPDATE
well after 2 days of running fine. Including most of today. The fast clicking noise and the high beams stuck on and the no head lights is back. So back to square one. No ideas what is going on, if some people could chime in I would really appreciate it
Old 03-13-2022 | 08:01 PM
ahab's Avatar
I'm with mollusc. Pull the fusebox and at least have a look.
Quick Reply: Weird head light situation
