Weird issue (tach)
Old May 5, 2007 | 12:03 PM
Brad S1's Avatar
Default Weird issue (tach)
Tach isn't working right. Sometimes it works without issue, othertimes it doesn't work at all, and yet sometimes it will just spring into action at random...
What could be causing this?
Old May 5, 2007 | 01:20 PM
okdiscoguy's Avatar
Default RE: Weird issue (tach)
have you checked your battery and alternator? a dying battery can make your tach go crazy. Other than that, check for loose wires..
Old May 5, 2007 | 06:01 PM
Even more then the battery, your tack gets it's signal from your alternator, so first check for loose or dirty wires, if they are fine, I wold say your alternator is starting to dye on you.
Mike
Old May 7, 2007 | 12:35 AM
Brad S1's Avatar
How did I know such a simple issue would be coupled to a 1000 dollar part... hahaha...
Wires are fine, tach was working today but better safe than sorry time to hit ebay..
Old May 7, 2007 | 02:37 PM
Don't go to E-Bay for an alternator.
First it isn't a $1000 part. Look around your town for a shop that rebuilds them, you can get it done for under $200.
Mike
Old May 7, 2007 | 03:43 PM
Brad S1's Avatar
Great info as usual mike... The rover dealer quoted me $1500... I saw they're 195 on ebay, and 225 on a part site... Why not buy a new one?
As for the rebuild? Is there a kit for this, possible to DIY? Thanks again!
Old May 7, 2007 | 07:28 PM
You can do that, they are pretty expensive especially if you have a D2 with the 130Amp unit. I especially like the cost of the 2 options Rover Connection has.
Mike
Old May 7, 2007 | 08:02 PM
Aquaholic's Avatar
From my experience - and after speaking with several mechanics - Alternators have one of the highest DOA rates, especially cheap aftermarket ones.
Old May 8, 2007 | 01:02 PM
StevenDiscoII's Avatar
Aquaholic, please clarify "DOA"
Old May 8, 2007 | 02:18 PM
Brad S1's Avatar
So the stock alternator can be rebuilt? Is there a kit you can buy to do this? I've had alternators apart many times so I doubt I'd have an issue swapping new parts into it. Is there a place to purchase the correct internals online?
