Weird Leak Detected
Old Apr 2, 2009 | 07:59 AM
03DiscoSE's Avatar
Default Weird Leak Detected
Ok so I did a smoke test last night and found 3 leaks. One was a pin-hole in the intake boot..... Another appeared to be coming from the lower intake manifold. How much of a pain is that to replace? I just had the upper intake gasket replaced last week. The weird place that smoke was coming from was around the nylon bushing that the throttle cables pivot on on the throttle body?! Anyone ever heard of this before?
Old Apr 2, 2009 | 11:35 AM
The leak at the t/plate shaft is no issue. Exactly which seal did you just replace, was it the one between the upper and lower manifold?
Old Apr 2, 2009 | 03:17 PM
03DiscoSE's Avatar
Yeah it was the one that is open once you remove the intake to do the wires. The throttle plate shaft isn't anything to worry about? Honestly I think there was more smoke pouring out of there then the boot and manifold combined LOL
joefresso
May 4, 2011 08:31 AM
safarisam
Aug 27, 2010 02:36 PM
mtat
Oct 2, 2008 10:03 PM
auburndmbfan
Mar 23, 2008 11:09 PM
xb70valkarye
Oct 23, 2007 12:50 PM
