Well here it is........My project Disco
Old Feb 7, 2020 | 01:53 PM
Rove Again's Avatar
Default Well here it is........My project Disco
Brought my 2004 Disco II home today! Let the adventure begin...or should I say let my bank account end!!!! I’m confident in this purchase. I have a great base to start with. Stay tuned for the transformation!!!!
Welcome home!
Maybe a little suspension sag. New shoes and suspension coming soon!
Old Feb 7, 2020 | 02:17 PM
Discorama's Avatar
Love the exterior color. How many miles? What did you pay?
Old Feb 7, 2020 | 02:53 PM
Rove Again's Avatar
151,xxx miles. SERVICE RECORDS UP THE WAZZU!! Paid $4500. Thank you. I wasn’t too particular about what color I got, but I do like it!
Old Feb 7, 2020 | 03:09 PM
Richard Gallant's Avatar
Hi and welcome to the madness of buying anything english designed
Old Feb 7, 2020 | 05:46 PM
Extinct's Avatar
Some things can be prevented, some things cannot.
Preventable:
1. Overheating - replace all cooling system components not recently replaced. They all fail at your age/mileage level. Bypass thermostat is more reliable than the best LR designed stat.
2. Oil leaks - PCV mod
3. Headliner damage - pull it out now and start working on sealing the sunroofs. I can walk you through it.
4. Cowl breakage - due to UV exposure - remove and coat/paint.
5. Hood/Roof fading - park inside, UV coatings, wax frequently, etc.
6. Wiring issues - replace the old broken/cracked wire looms - they protect the wires from UV and heat exposure.
7. Sunroof motor failure - see #2.
8. Window regulator failures - pull the doors and grease the tracks
9. Popping door strap - liberal lube
Old Feb 7, 2020 | 06:22 PM
Discorama's Avatar
Sounds good. The roof rack is worth a thousand already.
My most rewarding upgrade was adding an oil cooler (factory from '02 with thermostat adapter [factory ports do not work]). It brings down the max oil temps by 20 deg F and extends engine life.
Old Feb 7, 2020 | 07:25 PM
CollieRover's Avatar
Extinct with excellent advice.
I would add use genuine hoses.
Old Feb 9, 2020 | 10:23 AM
cvhyatt's Avatar
Preventable:
@Extinct - I have the popping door strap issue. Drives me nuts. I have liberally coated it with wd-40 and then white lithium grease. What do you recommend?
Old Feb 9, 2020 | 01:29 PM
@cvhyatt Take a look at the strap, mine has ovaled drive shaft grease helps a bit, nothing else does. It really needs to be replaced but that is a ton of work on these
Old Feb 9, 2020 | 07:46 PM
Extinct's Avatar
Yeah, once they are popping you really just need to replace it. Junkyard or one of the forum breakers. Good excuse to lube the window tracks.
