Well I guess I’ll do the transmission too
Old 05-02-2020 | 07:57 PM
escott16's Avatar
Default Well I guess I’ll do the transmission too
I just posted about replacing fluids in diff’s and transfer case but while I’m doing it all why not just do the transmission, since it hasn’t been touched since I’ve owned the truck at 40k miles and have no records of it being done. What brand should I get and should it be synthetic? I found old threads from over 10 years ago but I’m wondering if there is any current suggestions and if you have the right product can you please link it specifically so I don’t get the wrong type? I’ve never changed trans fluid in my life.i will also change the filter with the one on amazon that’s 20.92$
Old 05-02-2020 | 10:12 PM
XRAD's Avatar
I took mine to local shop. They did front + rear diffs, transfer case, and transmission fluid for something like ~100$. It was well worth it. Mechanic sent me a pic of mud colored oil in the front diff. .....
Old 05-02-2020 | 10:22 PM
escott16's Avatar
any good shop recommendations? I know you don’t live near me I live in Pittsburgh but like reputable auto chains or should I go to a transmission place vs a regular auto shop chain. How do I know they are putting in the right stuff. I thought about doing it at a shop but everyone claims it’s super easy but if it’s around a hundred give or take then I don’t mind paying someone
Old 05-02-2020 | 10:33 PM
XRAD's Avatar
The local shop I use is the service center (nice 10 bay clean shop) for a medium sized used car dealer. they specialize in maser, Bentley, rovers, bmw, jag, etc....
So I would search for something like that in your area.....
Old 05-02-2020 | 10:44 PM
escott16's Avatar
only local European place near me ripped me off for 1200$ to do rear abs sensors and a shutter valve when I first bought the thing and after I learned about the car and am able to do all that myself I will NEVER return but I’ll try researching around.
Old 05-03-2020 | 08:32 AM
Red5's Avatar
I used Valvoline Dex/Merc a couple of yrs ago, no problems since. If the shop wants $100 and that includes a filter, I'd be tempted. More than that and I would do it myself, it's an easy driveway job. I used about a gallon I think, and get a pump if you don't have one. The type that screw into the top of the bottle are easier than the inline type for me. Pump till it drips, plug it, start the engine and work it through all of the gears, put it in P and leave the engine on, check the level again and top up if needed.
cvhyatt (05-03-2020)
Old 05-03-2020 | 08:50 PM
Discorama's Avatar
I got the kit from AB (filter, gaskets) and DexIII + 1 bottle of Lucas. Watch the video on AB. I did a flush first (drain and refill without pan removal), drive a few miles until hot. Then drain, remove the pan, do the filter and gaskets, refill with a bottle of Lucas. Easy job. 14,000 Miles driven since then, transmission works great.
Richard Gallant (05-04-2020)
Old 05-03-2020 | 10:33 PM
escott16's Avatar
Is this alright this is what I’m getting
Old 05-03-2020 | 11:39 PM
Old Bertha's Avatar
It says it’s compatible with dex/merc on it but I’m still gonna say to just be safe and get the actual blue jug of Valvoline dex/merc. Walmart has it $14 a gallon.
https://www.walmart.com/ip/Valvoline...allon/15125788
also Atlantic British has a great walkthrough video for you to follow
Old 05-04-2020 | 12:09 AM
escott16's Avatar
Ones synthetic the others not. Assuming mine has never been changed which should I use
Quick Reply: Well I guess I’ll do the transmission too
