What’s this wheel make a model?
Sixpack577 (07-20-2018)
I have no personal experience with them.
I have worked on cars and bikes for many years, but this is my first LR.
I've had it just over a year, and had/have to fix so many things, it's made learning this thing easier.
LR wheels are not something I know about.
The po of my 04 put some gangsta RR 20" wheels on it.
And, even though I like them, they're not me.
The plan has been for black steel wheels, AT tires, and 2"-3" of lift.
I was happy to see you had black spoke wheels, and hope I can find some.
From what I understand is that if your wheels are made for a LR, then no hub centric rings should be needed.
If they are for anything else, but still bolt up, then you need the rings.
From what I can see in your pictures, it looks like your wheels fit snug around the hub as they should for a LR wheel, and should not need rings.
Hopefully someone else here can clarify.
They are rings that make sure the wheel is centered around the hub. Apparently there are alot of wheels that will bolt to a LR, but if they aren't specifically made for a LR, then they need a ring to keep the wheel centered.
![](https://cimg3.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/image_8e43138f338fb1c514d0c4850ecb8a20deabb542.jpg)
TaylorCadence (07-20-2018)
Again, D2 specs are: 5x120.7 / 30-40mm offset / 14x1.5mm bolt sizing / and whatever size wheel you need aka diameter and depth
The following 3 users liked this post by TaylorCadence:
astromikey
02-27-2018 02:59 PM
