What air and oil filter do u use?
Most recommend using the OEM Land Rover Part, but I just replaced mine about a week ago with an STP filter from AutoZone. I think as long as you stay away from the K&N filter you can't go wrong. The oils used on the K&N filter have been suspected to cause your Mass Air Flow Sensor to malfunction. Although my Disco II had one on it with no MAF sensor problems...and im at 123,000miles. No telling how long it had been on there either.
I use the Mobil 1 filter for the oil. There is a difference between that and the cheaper ones. I usually get the "oil change specials" from Advanced where you get like 5 qts of M1 oil plus the M1 filter for $27 or so. Not a bad deal considering the filters are $13 on their own. Buy 3 of the specials (since you need more oil) and then have the extra filter to use for another change, or get a filter for something else.
For air, anything like Purolator will be fine. I just stay away from bargain brands in general.
