What brand of brake rotors and pads are recommended?
Old Sep 26, 2012 | 10:11 AM
Antmen's Avatar
Are you asking if the truck sits for days? Mostly morning school and sitter dropoffs (2-3 mile drive) and again afternoon school and sitter pickups (2-3 miles.) During the major part of the day, it sits.
Then, of course, out and about on weekends (it gets, on average, only about 800-900 miles per month.)
-Anthony
Old Sep 26, 2012 | 11:46 AM
drowssap's Avatar
they also appear to be bare metal, not zinc coated
Old Sep 26, 2012 | 12:07 PM
bballjames's Avatar
F+R Drilled Rotors for Land Rover Discovery Series II | eBay
I just put these rotors on a couple weekends ago. They are nice quality, fit perfect, and are a very decent price. I also put the akebono pads on with these. About $300 for everything. My stopping is nice and smooth and no squeals. These rotors are zinc coated as well so they shouldn't rust out too quickly. Overall I was very pleased with these.
Old Sep 26, 2012 | 12:15 PM
-Anthony
I was only asking because that is the sort of rust you would expect to see if the truck had been parked for a couple of weeks.
Hate to ask, where did you buy these, what brand?
Old Sep 26, 2012 | 12:19 PM
mwindth's Avatar
LR original equipment rotors, Akebono ceramic pads (EUR676 for the fronts and EUR493's for the rear) and HD synthetic brake fluid (Dot 4 ONLY).
Old Sep 26, 2012 | 12:20 PM
Antmen's Avatar
Originally Posted by Disco Mike
... Hate to ask, where did you buy these, what brand?
You missed that part of my post. I got them from Atlantic British (not the OEM ones, just the "standard" or "generic" ones):
Land Rover Discovery II Brake Rebuild Kits: Land Rover Brake Kits Online
'Might as well let these run their course and then go zinc-coated on the rotors and Akebono on the pads. Stopping is smooth and no squeaks, but if they continue down this path, I don't see them lasting very long.
-Anthony
Old Sep 26, 2012 | 09:02 PM
ZB-30's Avatar
I have DBA rotors and Akebono pads, no complaints whatsoever.
Old Sep 27, 2012 | 01:29 AM
jfall's Avatar
You can' t just mix and match brake pads and rotors.
OK, well you can try.
Most of the combinations you try will have brake pad squeal under certain temps and pressures.
You need to stick close to OEM pad compositions.
None of this ceramic aftermarket stuff. Makes less dust true.
But, squeals like a pig mostly when stopping.
Will **** off your wife - for sure.
Old Sep 27, 2012 | 02:49 AM
bootzilla's Avatar
Just put on EBC rotors and Akebono pads. Stops smooth and fine (way better than the warped rotors that were on previously). Still stops like a truck, though.
I do need to do the fluid, still.
Old Sep 27, 2012 | 07:41 AM
-Anthony
OK, here is my belief, you have purchased an inexpensive set of rotors made using a cheap mix of alloys and they are just going to rust.
I would be concerned because at some point this rust issue will set off your 3 Amigos and cost you money. Are they squeaking at all, if so I would talk th A.B. and let them know of your issue so if this happens they will warranty/sell you a different set made to a higher standards.
