What brand of head gaskets?
Old May 19, 2010 | 10:48 PM
TBIAgent69's Avatar
Default What brand of head gaskets?
I have used Felpro gaskets every time I have replaced head gaskets in the past. They make them for the buick engine that the 4.0 is based off of. Has anyone tried these on a rover? They are supposedly thicker than the OEM ones, which, although will reduce the power a little but could help a lot with reducing operating temperatures.
I suspect they would work better than anything else out there but I am looking for anyone who has actually used them before. In fact, I'd be willing to bet that cutting head gaskets out of a cardboard box would work better than the factory ones.
Old May 19, 2010 | 11:46 PM
Willie00d2's Avatar
Atlantic british sells a good set. Also change your head bolts. Use a good quality 5/8" 6 point socket. The new head gaskets are supposed to be improved over the stock gaskets.
Willie
Old May 20, 2010 | 05:36 AM
vandev's Avatar
Default these also
these also have been said to be very good...
http://www.cometic.com/est.aspx
Old May 20, 2010 | 08:27 AM
hilltoppersx's Avatar
i also recommend the AB kit. comes with a whole dump load of fun gaskets to replace while you are there.
Old May 20, 2010 | 08:29 AM
And when you buy them make sure to get new U.S. made head bolts and a t/stat.
Old May 20, 2010 | 10:15 AM
audiS4S6's Avatar
I priced these and passed at ~$95 each.
I bought a complete head gasket set and bolts from fap99.com and the head gaskets themselves from British Atlantic - saved me a bunch over buying it all from BA. That was for a DI anyway.
Old May 20, 2010 | 01:30 PM
vandev's Avatar
Default yes expensive..
Yes they are expensive but you wont have to do them again...and again...and again.....again, and again..... well thats the thought anyway...
Old May 20, 2010 | 09:10 PM
audiS4S6's Avatar
I don't know that this has been proven. I am sure they are the best but I went for the composite ones from BA.
If they do solve the head gasket problem for good, they would definitely be worth it. I think the engine design may have a lot to do with the failures. Has anyone used the Cometics?
Old May 20, 2010 | 11:02 PM
TBIAgent69's Avatar
I would like to try mainstream land rover replacement gaskets, but, for some reason I have a hard time believing that anything made for our vehicles is designed with quality or longevity in mind.
Old May 20, 2010 | 11:21 PM
lordmorpheus's Avatar
Oh, that is so not true! Why, just off the top of my head I can think of dozens...well, ok, just two items that have been redesigned to correct problems:
metal idler pulleys replacing the plastic ones (ok, LR probably got a deal on metal pulleys from some supplier)
redesigned upper radiator hose (ok, LR probably saved a lot of money placing the bleed screw in the plastic hose connector rather than having to mold it into the rubber hose)
/end sarcasm
VikingDiesel
Oct 16, 2012 06:45 AM
RROJ
Mar 26, 2011 02:37 PM
rvrguy
Nov 18, 2010 12:52 AM
