What could this Noise be?
Tomorrow im going to check the linkage at the point where it connects to the T-case. Something is not right. Im about 99% sure now that the CDL is still halfway engaged. n
I've only driven a few yards so I hope it hasnt done to much damage to the gears....
Can I just say, "IF" the CDL light is "ON", then the CDL "IS" engaged!!!.............remember that guys !!
Because of the way it works, it is NOT possible to have the light ON but not engaged. If your not 100% on it, simply jack up one front wheel, if you cannot spin it then the CDL is still in, you may even find that will "unwind" the transmission and put the light out. If you were on a surface where ANY of the 4 wheels can slip, then it is unlikely you have done any damage.
